How consoles works in 16:9 screens?
Discussion in 'Plasma TVs Forum' started by Dreamboy, Jun 17, 2004.
  1. Dreamboy
    Dreamboy
    Jun 15, 2004
    109
    16
    Apart from my LCD vs. Plasma problem I have a big question when buying my new TV.
    Until now I allways had 4:3 format TV's. I use to play with my XBox and the image of the console is 4:3. I'm wondering how 16:9 TV's handle console images.
    Does the image look streched? Does the PlayStation 2 or XBox have panoramic modes? Are some parts of the image cut?
    This would be a big problem if image is cut affecting score boards or game information on screen.
  2. johndon
    johndon
    Feb 3, 2002
    1,988
    63
    +122
    I'm sure, on the XBOX at least, that you can select widescreen or 16:9 for the output.
    I've always used mine on a widescreen TV and never had a problem with the way games look.
    John
  3. Waser
    Waser
    Mar 1, 2004
    1,059
    Purley, Surrey
    +86
    Xbox has a 16:9 mode in the settings. The PS2 doesn't to my knowledge. You can always select the 4:3 mode on your TV and play in that ratio with the black borders on the screen. All widescreen TVs have that option.
  4. Dreamboy
    Dreamboy
    Jun 15, 2004
    109
    16
    Setting the 16:9 mode on the XBox will adapt all the games? I know that I can use wide screen TV's in 4:3 modes but then I only use a part of the screen that is a little disapointing.
    Also I've heard that using 4:3 on a plasma monitor can cause screen burn as image is not shown in the sides.
  5. Waser
    Waser
    Mar 1, 2004
    1,059
    Purley, Surrey
    +86
    I think all Xbox games come suitable for 16:9.
    That's a big problem with Plasmas, burn in. Most gamers would say the technology to go for if you want a flat screen and you are a gamer is LCD.
  6. Dreamboy
    Dreamboy
    Jun 15, 2004
    109
    16
    It's great to know that XBox can use the 16:9 format. About the burn in i'm really worried as consoles can have many static parts on the image for some time.
    I've read a lot about this in this forum and seems that lots of people uses plasma + XBox without problems. I was goint to buy a 30" LCD Sharp but yestarday I saw the 42" LG Plasma for the same price and the image size difference is impressing. I can't even sleep trying to make my decision. :(
  7. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    big ps2 player here and on some games in the options in the game its self you can set the ratio to 16:9. i think fifa 2004 allows this as well as GTA:VC. pity all games dont have this option but most newer games do
  8. johndon
    johndon
    Feb 3, 2002
    1,988
    63
    +122
    I've used an XBOX on a Hitachi plasma for nearly a year now and have had no problems with permanent screen burn. I occassionally get image retention but this goes away after a few seconds when I switch back to normal TV.
    HTH
    John
  9. codlord
    codlord
    May 17, 2002
    283
    Portsmouth, UK
    The PS2 does have a 4:3/16:9 mode in its own settings menu but I really don't know exactly what it does - I have mine connected via the S-Video input and it always fills the plasma screen regardless of the PS2 setting - although it does look slightly different, but cant really explain how. All games seem to look o.k. though.
    Also as someone else pointed out some games have an option too - I think this just adjusts the width/height ratio so the screen does not look stretched even if it has been stretched (by plasma or PS2 settings) - at least thats how it looks when I fiddle with that setting on GTA Vice City.
    Plasma options to stretch/zoom a 4:3 image will depend on plasma model and connection type.
  10. Dreamboy
    Dreamboy
    Jun 15, 2004
    109
    16
    Thanks for the comments. Now I'm less worried. :)
    Maybe when setting the panoramic mode in the XBox the resolution changes to match the 16:9 screen size. This wuold be perfect and the image is not distorted in any way.
    I've heard of image retention but this doesn't worryes me if it disapears in a short time. What frightens me is permanent burn in.
  11. jerkyboy
    jerkyboy
    Not all Xbox games are in 16:9 , in fact I would say less than half are.
    Its pretty simple, if the game supports widescreen then it will output widescreen. If the game does not then it will be in 4:3.
    Anyone who tells you different has no idea what they are talking about !!!.
  12. reckless
    reckless
    Dec 21, 2003
    987
    28
    +30
    Could anyone with any console and a widescreen lcd answer this for me please. I had a plasma which I had to return but during the time I had it, I used my ps2 to play pro evo on it and I thought the picture was great.
    However, I'm currently debating getting a LCD as a replacement for the panny but I have noticed that some LCD screens I've seen console games running on seem to look exactly like my TFT monitor does when it's running games at the wrong resolution, i.e. slightly blurry, particularly with text.
    I didn't see this with the plasma and assumed it was because even though it was running at a resolution which the console was not outputing, the scaler simply adjusted the image size to what was, to my eyes at least, quite pleasing. I assumed the scalers on the LCD screens do the same but seeing some of these images has worried me a little. In all honesty, I've not checked what settings the lcd screens were on, they may have all been on zoom mode or something of that type but I'd really be interested to hear if anyone has noticed that games look more blurry on lcd than plasma. Could it be because the panny had a lower resolution than the average lcd screen or am I simply imaging the entire thing.
    Grateful for any comments!
  13. Dean
    Dean
    Jun 20, 2003
    2,945
    London
    +299
    Of course the PS2 has 16:9, you think Sony would miss something like that :laugh: Just be careful though cos some games require you to select 16:9 in the game menu as well as the console system menu
  14. cb31
    cb31
    May 17, 2004
    30
    I've got an xbox connected to my plasma using the HD pack. At 480p and 720p it is simply stunning, much better than using the scart connection. I have never noticed any image stretching and wouldn't dream of forcing it to 4:3 if the game doesn't support widescreen. I sometimes get some brief image retention but it goes very quickly and is unnoticeable on normal tv.
    I also have a gamcube connected to a 16:9 17" lcd and the image is pretty hopeless. However I am using composite so expect the picture to be not that great. Whether it is the lcd or connection or combination of both I am not sure.
  15. Waser
    Waser
    Mar 1, 2004
    1,059
    Purley, Surrey
    +86
    Hey, Sony forgot to include the harddrive so why not widescreen... :p
  16. Dreamboy
    Dreamboy
    Jun 15, 2004
    109
    16
    LOL! :laugh:
    What's this 480p and 720p thing? There's diferent resolutions for the XBox to work? How can be changed? And was has this to do with the SCART connections. Sorry I'm very confused.
  17. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,289
    Norwich
    +877
    In the set up menu under VIDEO you will have the options for WIDESCREEN and Pal 60 if you have a Pal xbox, If you have an NTSC XBOX you will get the WIDESCREEN option and also you can tell the XBOX what reolutions your display can handle, most games support 480p, and some also support 720p and 1080i, you will have to have a component cable plugged in for these options to come up.
    You can chip your xbox then run the Enigma video mode disc to set your XBOX to NTSC, that way you can use progressive scan and hi-def from a UK xbox.
    I never worry whether the game is true 16:9 and always run my display in 16:9 format, so what if a character looks a little shorther than normal, it is a videogame after all, it doesn't effect gameplay and fills the whole screen.
  18. Dreamboy
    Dreamboy
    Jun 15, 2004
    109
    16
    Wow! Thanks for the information. My XBox is PAL and I have already modded it. I don't have component connections as PAL systems usually comes with SCART connectors. I don't know if it's the same.
  19. PC Nut
    PC Nut
    Jan 11, 2004
    649
    South West
    +65
    Not the same at all dreamboy, For high definition from xbox you will also need the high definition lead, avaliable state side, just had mine picked up by a friend for $19.99 £13.00
    HERE £29.99 Ripoff
  20. Dreamboy
    Dreamboy
    Jun 15, 2004
    109
    16
    I've seen the high definition cable in the link. There's information about how it works and didn't kneew this was available for the XBox. But it says that this only works with USA XBox with USA games. Mine is european and I'm not sure if it can work with this.
    Also I'm not sure what modes support the TV I want to buy. I'm looking for the 42" Plasma monitor LG MU-42PZ44.
  21. PC Nut
    PC Nut
    Jan 11, 2004
    649
    South West
    +65
    As mentioned above, only chipped xbox's work in UK using the HD output with pal and ntsc games.
    MORE INFO HERE
    Your screen will supports the following:-
    Input Signal NTSC/PAL/SECAM, HD, VGA-SXGA
    Component (Y,Pb,Pr) & Audio (480i/480p/576i/576p)
    Resolution 852 x 480
    Only HD panels will support 1080i/720p as the LG model is only SD the modes avaliable are listed above
    MORE INFO HERE
  22. Dreamboy
    Dreamboy
    Jun 15, 2004
    109
    16
    Great thanks for all the info! Wow looking at the specs I've seen that it consumes 320W Is this the average for a Plasma monitor? CRT TV's have much lower consumption.
    Anyway I thing this is great for his price. I hope to have it soon. :p
  23. PC Nut
    PC Nut
    Jan 11, 2004
    649
    South West
    +65
    Yes 300w and above is normal, :cool:
    saves having the heating on in the winter
  24. Dreamboy
    Dreamboy
    Jun 15, 2004
    109
    16
    Sorry. I did not get what you mean with "saves having the heating on in the winter".
  25. PC Nut
    PC Nut
    Jan 11, 2004
    649
    South West
    +65
    300 watts = plasma panel or plasma room heater. Hence no need for heating just a dig at the power consumption really.
  26. betamac
    betamac
    I use my Gamecube on my new Panny PWD6 and it looks soo nice in Progressive Scan, crystal clear
    Cant Wait !!!! For Resident Evil 4 that is gona look soo sweet!
  27. Dreamboy
    Dreamboy
    Jun 15, 2004
    109
    16
    So you mean that plasma panels generate lots of heat? That's great in winter but not so great in summer... Another point for LCD. It's really hard to choose.
    I was looking at the LG in the shop where they have it running for hours and it seemed it was not very hot. Any CRT I've seen get much hotter that this.
  28. Dean
    Dean
    Jun 20, 2003
    2,945
    London
    +299
    fair point :laugh: Though the PSP coming out later this year looks pretty good. Just got Driver 3 but haven't had time to play it properly yet :D
  29. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,289
    Norwich
    +877
    If it supports progressive that is, none of the others have.
  30. betamac
    betamac
    Dont think you can really compare any other Resident evil game to Resident evil 4, they have gone to town on the visuals and gameplay theres no way they would leave Progressive scan or Pro Logic 2 out,
    This will be the definate version of Resident evil upto now
