How commen are dead pixels on ae300
Discussion in 'Projectors, Screens & Video Processors' started by Norr, Oct 7, 2003.
  1. Norr
    Norr
    Hi!
    I'm a newbie and would like to buy an AE300 or an AE500 but shudder at the thought of buying an lcd pr to find a few months down the line I have dead pixels popping up.
    So, my questions are:
    1: How many people who started of with a NDP count now have dead pixels ?
    2. How many dead pixels do you now have ?
    3. How long has the pr run before they started to pop up ?
    4. At what point in the life of the pr are dead pixels more likely to appear ?
    Thanks in advance folks.
    :confused:
  2. ChrisNightingal
    ChrisNightingal
    Hi there Norr,
    Well I have had my AE300 since about May and at first it seemed that there wasn't a dead pixel. I'm not sure when it first appeared but it was a blue one that appeared in the center of the screen about 25% down from the top.
    It was only really notiable on very dark images and was a little annoying. You are obviously aware of Panasonic's policy on dead-pixels hence the thread so know that it can't be replaced without a certain combination/number of pixels failing.
    Well after reading up on these forums, I found a kinda solution to the problem which involved placing a coloured sticker in front of where the dead-pixel appears and it has done wonders. The pixel is almost impossible to see now from viewing distance.
    See for yourself:
    http://homepage.ntlworld.com/chris.nightingale1/ftvtp/ftvtpdpmainpage.htm
    And here is a link to a page I did a while back on the installation etc:
    http://homepage.ntlworld.com/chris.nightingale1/ftvtp/ftvtpmainpage.htm
    Please don't let this put you off as it's really a great little pj....
    All the best,
    Chris Nightingale.
  3. Mirablo
    Mirablo
    Jan 16, 2003
    70
    usually theyre there from the start its just a case of how long it takes you to see them. because as soon as you know its there you will ALWAYS be drawn to it.:thumbsdow
  4. Norr
    Norr
    Thanks for the reply guy’s.
    Am I correct in assuming that when a retailer states they have a NDP policy then the unit purchased should remain DP free for the life of the unit, Or am I stretching it bit!
    :zonked:
  5. zAndy1
    zAndy1
    Nov 26, 2002
    21,870
    2
    5
    163
    +8,298
    Oh no, a NDP policy means when you first receive it there will be no dead pixels, if any die during normal use it's tough luck, at least that's my understanding.
    Andy
