How come I don't have sound through 5.1 surround system?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Papsico, May 15, 2005.
  1. Papsico
    Papsico
    Hey,
    Every time I write a dvd (with my home made movie on it), and play it in my DVD standalone player, I only have sound through the television speakers, and not through my surround system. What am I doing wrong?
    Greets,
    Papsico
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Well unless your editing programme allows you to edit/mix 5.1 & has a 5.1 encoder your output will be stereo. You also need an authoring package that supports 5.1
    You won't therefore be able to get 5.1 onto disc & your DVD player will be playing the native stereo mix in either Dolby or PCM. The only way you will get pseudo 5.1 is if you play your stereo stream through a Dolby Pro logic II decoder.
  3. Papsico
    Papsico
    What do I have to do to get such 'pseudo-surround sound?'
  4. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    You have to have a DVD player or an Amp/receiver with a Dolby Pro logic II decoder.
    You feed it stereo it gives you pseudo 5.1
  5. Roy Mallard
    Roy Mallard
    Papasico, what kit are you using?
    true 5:1 surround origination is an expensive business requireing five mics (NOT A FIVE ELEMENT MIC as on some sonys) ballanced and mixed with an even placement perspective, then authored using a pro level dvd package (the likes of DVD studio pro for macs, Adobe thingey.. encounter I think) for PC (the wee cheat on Pinnacle 9 works up to a point)
    More kit info=more fix info
