How come hardly any tvs have surround sound?
Discussion in 'TVs' started by Bren, Jul 31, 2005.
  1. Bren
    Bren
    Jan 23, 2004
    1,645
    48
    +67
    Currently looking for a 32" widescreen & have none have output for rear speakers. Most have virtual dolby wich i'm guessing is not very good. I don't want an external home cinema system so whats the best option?
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Bren,
    It's the old "supply and demand" thing, I'm afraid.
    Those few people who are sufficiently interested in surround sound will generally invest in a separate system, as the built in TV speakers will not be good enough for the front/centre.
    (The basic Cinema Systems aren't that expensive, see Richer Sounds etc.)
    You are correct that Virtual Dolby is not up to much.
    I hope someone can recommend what you're looking for, but I suspect you'll be hard pushed to find anything worthwhile.
    Good luck! :smashin:
  3. CJROSS
    CJROSS
    Nov 16, 2000
    5,072
    +343
    Toshibas ZP48 range in both 32" (32ZP48) & 36" (36ZP48P) models, both are Dolby Digital 5.1 sets, ie they have 4 external speakers and an internal centre & subwoofer (quite effective actually), they dont cost the earth either, for a non cluttered 5.1 system quite hard to beat IMHO. An £200 AV Amp & £500 worth on speakers would improve on it, but thats the cost of the TV.
    PAL PS too via component.
    Stunning.
    HTHs
  4. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Hi, I thoroughly recommend the Toshiba 32ZP48. The internal surround sound features are more than adequate for our needs and have really enhanced our viewing pleasure of even the most 'mundane' programmes. Regards, yt.
  5. Bren
    Bren
    Jan 23, 2004
    1,645
    48
    +67
    Yes i have one of these myself but the set is for my parents & they don't want to send over £500 so i think that rues this et out.
