how close is too close?
Discussion in 'Home Cinema Speakers' started by Wilf, Jan 25, 2002.
  1. Wilf
    Wilf
    Jan 11, 2001
    375
    Staffordshire
    +6
    How close can you put non-magnetically shielded speakers to a screen. I guess its different with all speakers ( as the magnets used differ in size) but does anyone have a guide. I like the look of the B&W 602.5 s3 but don'nt have a lot of room either side of the tv. thks in advance
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,620
    United Kingdom
    +2,221
    My old Kef RDM1´s were´nt shielded and I had them about 8-10 inches either side of the tv without any problems.
    The Kef´s arent particularly big speakers though.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    No general rule as it depends on the magnet as you said, though at least 1 foot is recommended.
    If you put on an AV channel without a signal you should get a blue screen, if you see any change in color (towards green or purple) at some areas the speaker is too close ...
