how can you tell if your WD live is HUB or a SMP
Discussion in 'Video Streaming Boxes & Services' started by Goldeneyepad, Sep 7, 2012.
  1. Goldeneyepad
    Goldeneyepad
    Aug 13, 2012
    103
    How can I know if my wd live is a smp or hub?
    Trying to do thumbgen and the stuff not working on it
  2. planthead
    planthead
    May 10, 2005
    1,776
    63
    +231
    The hub has a built in hard drive, but essentially the same are you sure you need thumbgen, a third party renamer is all I use, and I am not sure I need that, just habit. The live and hub fetch data, automatically. Thumbgen was used a lot on the older wd tv live as it didn't have a scraper and worked well with hacked firmware. There were plenty of you tube tutorials at one time, but not sure if it's even being updated now.
  3. Goldeneyepad
    Goldeneyepad
    Aug 13, 2012
    103
    So plant head,
    His do you change your DVD/bluray covers to suit you?
    Because when I get info from wd live it sometime gives me a Asian film cover.
    Where I don't want that.
    I got my own films covers I would love to use, but I heard that thunbgen works doing that, but like I said its not even working that way.
    Third party you say, how dose that work?
  4. planthead
    planthead
    May 10, 2005
    1,776
    63
    +231
    If the movies are named correctly, the scrapers will work 99% of the time,
    The renamer
    Wd hubgen
    Media centre master
    Phoenix renamer
    File bot
    To name a few
  5. Goldeneyepad
    Goldeneyepad
    Aug 13, 2012
    103
    How do I use these?
  6. planthead
    planthead
    May 10, 2005
    1,776
    63
    +231
    Wdtv hubgen gives a choice of covers to select, but don't run these on vast file libraries, as it will crash. There were thumbgen tutorials with theme downloads on the wd community, you may have to search for them. As I have said there was a great deal of activity on thumbgen and movie sheets about 2/3 years ago.
  7. planthead
    planthead
    May 10, 2005
    1,776
    63
    +231
    You just drag and drop. Trial and error
  8. Goldeneyepad
    Goldeneyepad
    Aug 13, 2012
    103
  9. planthead
    planthead
    May 10, 2005
    1,776
    63
    +231
    There is a setting on the live to change the cover, you will have to dig around for it as I can't remember the correct steps.
  10. planthead
    planthead
    May 10, 2005
    1,776
    63
    +231
