How Can You Check The LG RZ42PX11 Firmware When Ordering??
Discussion in 'Plasma TVs' started by jimmyidle, Apr 14, 2005.
  1. jimmyidle
    jimmyidle
    Hi. Can anyone one tell me how to check the firmware version of a LG RZ42PX11. Can it be found out by the serial number when ordering it, as I would like to know I'm getting the latest one . If it can only be checked when I've already paid and had one delivered then I could luck out! Hope I'm making sense, I sort of know what i mean, hope some of you do!!.
    Thanks.
  2. reddevil63
    reddevil63
    Apr 12, 2005
    5,525
    Disney Florida's Twinned Town
    +851
    I need the answer to that also as going to look at the LG 42" today!
  3. DOCTOR_d
    DOCTOR_d
    Mar 12, 2005
    194
    The serial number gives it away.....
    If it starts 502 then it was built in february 05.
  4. Mep
    Mep
    Dec 25, 2004
    9,552
    +472
    make it a condition of purchase.
  5. jimmyidle
    jimmyidle
    Thanks all, will get them to check the serial number when I order.
  6. bananas
    bananas
    Dec 29, 2000
    89
    West Byfleet, Surrey
    Where are you getting it from?
    I recently had mine delivered from John Lewis and I was initially concerned as it said through the grill on the back that it was manufacturerd in Dec 2004, but it turned out to have the 5.14 firmware installed.
    Unless you're getting it from a very low-volume shop, I doubt you'll have a problem with old firmware.
  7. Daipac
    Daipac
    Apr 12, 2005
    658
    +12
    Once you actually have the unit up and running, how do you know what firmware version you have ?
  8. jimmyidle
    jimmyidle
    Going to try and get mine from John Lewis they give a 5 year guarentee with, if thats how you spell it.
  9. Ross-P
    Ross-P
    Mar 16, 2005
    391
    Guernsey
    +20
    Daipac - To check your firmware hold down menu on the remote facing the tv for ten seconds then hold down menu ( at the same time ) on the tv for ten seconds, a hidden menu will come up showing firmware and other settings ( don't change anything ! ) press yellow to cycle through menus.
