How can Ipod play all songs one after another. Help please
Discussion in 'Headphones, Earphones & Portable Music' started by Julio V, Apr 30, 2007.
Tags:
  1. Julio V
    Julio V
    May 16, 2005
    438
    +6
    Could you please show me how to play all songs/ podcast at once : one after another?
    My ipod is 80Gb Video 5th generation.
    I tried to set shuttle, repeat even to put some songs on the playlist but after finishing playing a song, I had to touch the Ipod to play the next one
    :suicide:
    please help
  2. JWALKR
    JWALKR
    Oct 13, 2005
    33
    11
    You should be able to do that by just pressing play when your iPod is turned on under >>Artists....that way it should play all albums by all artists one after they other.... Making a playlist isnt too convinient for 80gb collection of music... If iPod cannot do that then its a waste of money i guess.....:boring:
  3. Maidenpriest
    Maidenpriest
    Jul 18, 2005
    238
    +8
    can you not select 'All Tracks' or 'shuffle all tracks'?? if you can't then it is useless! IMO
  4. wormvortex
    wormvortex
    May 29, 2005
    5,765
    South of Heaven
    +443
    shuffle all tracks is in settings and play all tracks you just go to songs and click the first track and it will play through every track
  5. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    Yes you can however mines would take 10 days to listen to!!!!!!:D
  6. Brutos
    Brutos
    May 23, 2006
    1,113
    +108
    You just have to press play on "all" in albums, artists or podcasts etc and it will play them all in order.
  7. macmillan
    macmillan
    Sep 9, 2012
    I have no idea why Apple doesn't address this... or make it easier!
    When you go to your playlist on your Iphone (Ipod,too, i guess also) click on SHUFFLE and when the song begins to play tap the album screen in the center of the screen. This should bring up another screen showing the song and the playing time, and the continuous, repeat loop (mine is on the left hand side). On the right side you should see a shuffle button. tap this and it should turn blue. Presto. Problem solved. I hope it works for you. It sure has made my life a lot easier!!!:clap:
  8. Miss Mandy
    Miss Mandy
    May 29, 2008
    11,579
    Essex
    +4,475
    ***?! This thread is 5 years old and you bumped it to give an answer thats for a completely different product?
