How can I use a Creative ZEN in my car
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by MalcolmD, Dec 1, 2003.
  1. MalcolmD
    MalcolmD
    Jun 13, 2002
    84
    Plymouth
    +5
    Hope someone can suggest some options to be able to use my Zen MP3 player in my car.
    I used to use one of those cassette adapters for linking the unit to play back through the car stereo. However my new car only has a CD Player so thats no good.
    Would be really useful if anyone else has experience of trying to do the same thing.
  2. hutters
    hutters
    Aug 20, 2003
    722
    28
    Cambridgeshire
    +28
    You can use an FM transmitter or an FM modulator. Basically it plugs into the headphone socket and you tune the radio into it. There's a number of them out there on the market. Do a search on google.co.uk and it should point you in the right direction. Sound quality is not that good (and technically it is illegal to be using an FM transmitter, so the modulator would be better). I'm about to get one of these for my iPod.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    You could see if your HU has line in, some on the market do, then you just need a jack>2 phono lead connecting. FM modulators plug into your aerial socket on the back of HU so it will need removing.
  4. Zef
    Zef
    Apr 24, 2002
    221
    Hertfordshire
    +10
    Does anyone know any HU around the 150 mark that has Line in ?...
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    No idea mate best contact your local ICE dealer get some model no's and shop around.
  6. Zef
    Zef
    Apr 24, 2002
    221
    Hertfordshire
    +10
    ok ive had a look at this and there are some options IF you are buying a new, or have one of the following units
    Sony have a add on unit XA-300 that provides multiple input sources (including USB !) and includes passthrough for a CD changer. price about £80 can be used with any ULINK head unit.
    Pioneer do a similar thing for most units, about £80 again
    Blaupunk (sp?) do a lead that is basically two phono to a plug into the back of the unit, most units have two of these but some only have one thus you cant add a changer. Lead about £30
    Same for kenwood, Im going to get a MP3 cd player (currently on offer £130) and a lead that goes into the CD changer port (£29)
    I think Alpine do the same leads for both types of connector.
    Thats your options for basic multiple input into some headunits.
  7. tekmonkey
    tekmonkey
    Hutters,
    As a fellow iPodonian let me know what you think of the Icelink kit, I have an Alpine head unit which I want to link it into but I can't find anyone who does or is doing a digital version, It must be possible. Any thoughts?
    Regards
    Monkey Madness!!!!!!!!!!!!!
    Vive le apple!!
    Vive le iPod!!
    Gotta get rid of this beige box!
  8. Jason S
    Jason S
  9. Northerner76
    Northerner76
    Sep 11, 2005
    926
    28
    Wells, Somerset
    +26
    Hi - my missus has a year old BMW 3 Series 325ci sport convertible... this has the bog standard BMW stereo/cd system...
    She also has a 30Gb Creative Zen Xtra (couple of years old) that has USB 2.0 and a headphone out socket...
    Anyone know of a simply solution so that she can listen to the Creative through the BMW's stereo system?
    I have looked at the FM transmitters but unsure if they are ok with the Creatives... all seem to focus on the iPod and I don't know therefore if they have generic connectors... (prod specs on wbsites are awful)
    Any ideas?
    EDIT: just found this which might just do the trick http://www.creative.com/products/product.asp?category=13&subcategory=57&product=11427 - creative belkin tunecast!!
  10. Donnacha
    Donnacha
    Jul 4, 2002
    8,091
    York
    +4,241
    I bought a cheap FM transmitter off ebay (around £7). It hooks into the headphone out on my ZEN Micro (and Archos) and into the cigarette lighter socket in the car.
    Just tune your radio to the fm frequency, press play on the ZEN and you're away!! Simple as that!
  11. Edward Catflap
    Edward Catflap
    Apr 5, 2005
    100
    +9
    Does the cd player have a multi-changer/aux socket in the back? If so then you can probably get a lead like this that I got for my Kenwood car stereo as presume other brands make them too.
    http://www.justkenwood.co.uk/stock01/auxin.asp
    One end into the back of head unit, the other into headphone socket of Zen & away you go - thousands of songs at your fingertips. If you live in a town/city, I'd be very wary of taking the FM transmitter route, as I tried that & there's way too much interference from pirate radio & from being in a built up area.
  12. Kurchatov
    Kurchatov
    May 21, 2006
    4,952
    Boston,
    +612
    Good advice. I've tried a couple of FM transmitters and whilst they do work the sound quality is much poorer than a direct connection and interference from other FM transmissions can be a pain
  13. Sonic67
    Sonic67
    Sep 14, 2006
    39,120
    9
    167
    Home
    +15,888
  14. TheDufster
    TheDufster
    May 21, 2002
    99
    11
    Leeds
    That looks fantastic, but seems to be only available in the US. Anyone know of a "plays for sure" in-car solution for the UK?
