how can I turn windows media files into mp3??
Discussion in 'Headphones, Earphones & Portable Music' started by Bristol Pete, Jan 31, 2005.
  1. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    hi,
    Brand new MP3 player. Spent the weekend copying ac/dc albums onto my harddrive to learn some tracks for my band. However, I cannot get them onto my mp3 player because they are wma.
    Can anyone tell me a way of turning the said files into mp3 and making it work.n Its doing my nut in!!!
    Is there a freeware solution out there?
    Thanks,
    Cap :)
  2. dogslikeyou
    dogslikeyou
    i have managed to get hold of a programme called "audio converter All-in-one" as a trail but with a little bit of digging i found a crack. unfortunatly it was a few months ago so i cant remember web sites! but i recall i looked for both the software and crack off of search engines ( keep looking it is out there)
  3. mick's cat
    mick's cat
    Try:
    http://www.versiontracker.com
    which is a site that keeps tracks of all known Windows, Mac amd Palm software. Choose the tab for which OS you have, then do a search for something like 'wma to mp3' to get results.
  4. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
  5. Sandman
    Sandman
    Nov 28, 2002
    3,123
    Glasgow
    +704
    Just download the latest windows media player (version 10), it rips to MP3 format.
  6. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    It rips CD's to MP3 but don't think it converts wma to mp3...?
  7. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    thanks guys, will give it a go.
    Cap :)
  8. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
  9. roseda.y00
    roseda.y00
    i had the same problem, that i couldn't get WMA onto an MP3 player, so i searched on Google for a free file converter, they arent hard to find :thumbsup:
