How can i turn down sound in Internet Explorer?
Discussion in 'Computer Components' started by Barney_Tabasco, Jun 4, 2004.
  1. Barney_Tabasco
    Barney_Tabasco
    Feb 5, 2001
    620
    Sheffield
    How can i turn down sound that comes from websites yet still keep the volume of Windows Media or RealPlayer?
  2. The Dude
    The Dude
    May 21, 2004
    4,905
    Beverley, East Yorkshire
    +1,229
    you could do it the other way round, but i guess that's not too much help :mad:
    I think you're stuck unless anyone knows any better ?
  3. Barney_Tabasco
    Barney_Tabasco
    Feb 5, 2001
    620
    Sheffield
    Basically, i have Radio 6 playing through PC for the whole office but i am currently working on a website and when i do the sound comes through Explorer!
  4. The Dude
    The Dude
    May 21, 2004
    4,905
    +1,229
    you can turn off sounds in IE, but you cant turn them down..
    as both IE and Realplayer are controlled by the WAV volume in the audio control panel..
    Any good?
  5. Barney_Tabasco
    Barney_Tabasco
    Feb 5, 2001
    620
    Sheffield
    Well the radio is playing through Windows Media Player but if i turn down volume in control panel it turns down the whole lot!
  6. The Dude
    The Dude
    May 21, 2004
    4,905
    +1,229
    yep, that's what you're stuck with..
    As far as Windows is concerned, any sound other than CD Audio is played through the wav mixer, so if you turn the volume down it turns everything down.
    All you can do is turn off sounds alltogether in IE while you've got the radio on..
