C
Cef
Hi, I need your help. I just purchased a JVC AV-29 BF11 ENS. Unfortunately, the picture is tilted slightly to the left. How can I rotate the picture? I found out that the service menu can be accessed by pressing "i" and "mute".
The service menu contains the following options/settings:
OSD 052
IF1 005
IF2 068
IF3 003
IF4 062
AGC 053
VLIN 007
RGBH 008
VSOF +03
VPOF -01
HSOF -02
HPOF -05
HTOF -02
WR 036
WG 031
WB 033
BR 026
BG 022
APR 004
BRI 031
CON 040
COL 024
SHA 006
HUE 031
VOL 009
WR-R 035
WG-R 038
FMP1 011
NIP1 028
SCP1 011
SEC1 081
FMP2 015
NIP2 045
SCP2 017
F1H 00001101
F1L 00010010
F2H 00011110
F2L 10000010
BS1 00000001
BS2 00000010
BS3 00001000
CB 10001110
OP1 11110111
OP2 00001001
OP3 01101100
OP4 00001000
OP5 00000000
TX1 01010110
GEOM 00100000
OP8 00000100
Once in the service menu, pressing the green button brings up another menu, titled "Geometry", which has the following options:
VSIZ 057
VPOS 019
VSCO 003
VCCO 007
HSIZ 019
HPOS 032
HPIN 008
HCCO 011
HTRP 012
VZSZ 006
I could not find another menu. I have tried changing several of the settings, but none did rotate/tilt the lines.
OSD 052
IF1 005
IF2 068
IF3 003
IF4 062
AGC 053
VLIN 007
RGBH 008
VSOF +03
VPOF -01
HSOF -02
HPOF -05
HTOF -02
WR 036
WG 031
WB 033
BR 026
BG 022
APR 004
BRI 031
CON 040
COL 024
SHA 006
HUE 031
VOL 009
WR-R 035
WG-R 038
FMP1 011
NIP1 028
SCP1 011
SEC1 081
FMP2 015
NIP2 045
SCP2 017
F1H 00001101
F1L 00010010
F2H 00011110
F2L 10000010
BS1 00000001
BS2 00000010
BS3 00001000
CB 10001110
OP1 11110111
OP2 00001001
OP3 01101100
OP4 00001000
OP5 00000000
TX1 01010110
GEOM 00100000
OP8 00000100
VSIZ 057
VPOS 019
VSCO 003
VCCO 007
HSIZ 019
HPOS 032
HPIN 008
HCCO 011
HTRP 012
VZSZ 006
