How can I tell if its the inverter or the backlight failing?
ProDave
More details, make and model of set, inverter details etc please.
Typically there are 8 CCFL tubes. it would be unlikely for all 8 to fail. If it's a lamp problem, then you would see a dark band on the screen.
Most inverters will start up even with a fault, then trip a second or 2 later. Use that brief period to check if the screen is uniformly illuminated.
A lot of inverter faults can be fixed. I've just repaired mine which was simply due to some dry solder joints. I re flowed a lot of joints, particularly those on the transformers, lamp connectors etc, and it's working fine once more.
xtr3m3
Hi a common symptom of a failing backlight is a reddish/pink screen tinge on startup.
And this is caused because the voltage is dropped too low, right?
JohnyM
Unfortunately I haven’t got a clue. I had the red tint problem with a dell inspiron laptop a few years back. I was told the red tint was down to either a failing ccfl backlight tube or a bad inverter. Either way the screen would need to be replaced and it eventually was under warrantee.
xtr3m3
Unfortunately I haven't got a clue. I had the red tint problem with a dell inspiron laptop a few years back. I was told the red tint was down to either a failing ccfl backlight tube or a bad inverter. Either way the screen would need to be replaced and it eventually was under warrantee.
I have send dozens of different brand TVs to service because if those sounds and always it has been the power supply.
ezegyNAD
Its an LG M2294D
When it starts up the screen is flickering and dim. At first the flickering went away and the screen was perfect after that.
Nowdays it flickers, then goes black.
Theres no red/pink tinge or noise as far as i can tell.
I guess its the inverter then, thx for the replies.
