How can i 'straighten' vertical lines on my Panasonic flatscreen TV?
Discussion in 'TVs' started by spudgun, Feb 10, 2003.
Tags:
  1. spudgun
    spudgun
    On my Panasonic TX-PK2 flatscreen 28" TV the horizontal lines are all stright, but the vertical ones have a tendency to bow. This is most noticable when channel 4's square logo (the one that appears on some of their adverts) is on screen and also in the sky sports logo that appears in the top right corner of their broadcasts.
    I'm a bit of a newbie when it comes to messing about with TVs, so any help would be greatly appreciated :)
    Spudgun
  2. BigB@dJ@y
    BigB@dJ@y
    Nov 23, 2002
    257
    Lancashire
  3. spudgun
    spudgun
    Thanks for the welcome, however, the link you have posted appears to be broken. I will, however, try a search of my own and see what i can find.
    Spudgun
  4. Rookies
    Rookies
    Jan 4, 2003
    4,931
    103
    +349
    Now I though you both got user name familier ;) Dont suppose you seen me over there then :p
  5. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Sorry if I've mentioned this before guys.
    Linearity is dependent on your TV's power supply. If you set the contrast too high, the power supply often can't cope and linearity suffers as a result. Try setting the contrast surprising low - on my Panny TX32PL1 it's set atound 25-30% - and see if this helps.
  6. BigB@dJ@y
    BigB@dJ@y
    Nov 23, 2002
    257
    Lancashire
  7. spudgun
    spudgun
    Changing the contrast to 50% has made quite a difference, especially to the Sky menus. I'll check the service menu out later, thank you all for the help :)
