Question How can I setup Denon X2100W without remote control?
Discussion in 'AV Receivers & Amplifiers' started by Probolacha, Jul 16, 2018.
  1. Probolacha
    Probolacha
    Jul 16, 2018
    2
    4
    Brazil
    My remote control of my Denon X2100W is not available.
    I saw in Denon faq page that is possible to use the web control function os the smartphone app to do it but neither is able to do the most simple thing, select the language to start the setup.
    Is there any other way to do this without the remote control?
  2. Captain Jack
    Captain Jack
    Apr 20, 2003
    82
    +3
    Which app are you using? I usually rely on one of many remote control apps and use IR blaster in my phone to navigate around.
  3. Probolacha
    Probolacha
    Jul 16, 2018
    2
    4
    Brazil
    I'm using the Denon Remote App. I will try IR Blaster so. Thanks!
