how can i set up ps2 for surround sound
Discussion in 'Playstation Forums' started by 18j, Mar 11, 2002.
  1. 18j
    18j
    Mar 4, 2002
    108
    16
    is there a way of getting surround sound from a ps2?
  2. lechacal
    lechacal
    Aug 13, 2001
    711
    Cheltenham
    +66
    Yes, but you will need to have an amp/TV with Dolby Surround decoding, or a Dolby Digital decoder to hear 5.1 material. And plenty of speakers, of course:cool: .
    What setup do you have/are you thinking of buying?
  3. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    With a Dolby Prologic processor/amplifier connect the PS2 up by the phono connections. Maybe you have one on a midi system or something. This will give you Dolby Surround Sound.
    If you have a digital surround sound processor/amp, connect the PS2 by its optical out connection. This will, in theory, give you full Dolby Digital and DTS sound where available. However, I've only come across two games that use DTS in gameplay, and none that use Dolby Digital in anything other than FMV sequences.
  4. lechacal
    lechacal
    Aug 13, 2001
    711
    Cheltenham
    +66
    That's because the PS2 can't encode DD in real-time (TTBOMK). It can do real-time DTS, but the only people who've found a way to make it work without using hideous amounts of processor time are EA (so far).
  5. Doug
    Doug
    I have a PS2 connected to my amp via the optical out but I can't get DD (Metal Gear Solid 2) or DTS (SS Tricky) . Surely the amp should detect when these signals are being received and show the relevant DD/DTS in the display?
    Appreciate any help guys
  6. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    With MGS2 it's only in cut scenes, not during gameplay. You'll have to select the digital soundtracks with these games too, or they'll just send out normal stereo sound.
  7. EffTee
    EffTee
    Jan 20, 2002
    196
    Bristol
    +5
    NHL 2002 has a menu option for you to select sound format. DD & DTS are listed. I haven't tried it yet, but I'm expecting to get DTS over my optical cable when I give it a go.
    I hadn't appreciated that you could get DTS decoded in game on the PS2 and not DD.
    EffTee
  8. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    You have to ensure your PS2 is set up to pump out DD/DTS.
    Load in a DVD (movie not a game) and then press stop once.
    From the menu select Setup and then Audio Setup.
    Make sure all digital options are on and then eject the disk to save the settings.
    Also make sure the digital output is turned on in the console setup - displayed when no disk is inserted.
    You should now get 5.1 sound flying out of all speakers :)
  9. 18j
    18j
    Mar 4, 2002
    108
    16
    thanks guys, i'll look into it
  10. Doubledoom
    Doubledoom
    SSX Tricky has an option in the menu to output DTS. It will do this irrespective of the options you have set for movie playback.
  11. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Really? It doesn't work for me. I have to make sure all the digital options are on to get DTS or DD sound out of my games.
    It's a bummer though cause I don't have a DD/DTS amp in my bedroom only downstairs. So when I have the PS2 upstairs (it's normal resting place :) ) I have to set all the digital signals off so that I can increase the volume setting for DVD playback (which is a major pain - why couldn't they have set the volume at the +2 mark from the off???)
    If I don't turn them all back on and I plug it into my amp I get no DD/DTS signal :( I have to set all the options up again.
  12. Doubledoom
    Doubledoom
    Weird. Although there are different versions of the PS2 and maybe the software changed in that respect between yours and mine.
