how can i reorder my dvd recordings?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Halloween Jack, Jan 17, 2005.
  1. Halloween Jack
    Halloween Jack
    Sep 27, 2004
    275
    16
    i've got a pana e85 that i've been recording episodes of the simpsons on. i've also got a pioneer 108 on my pc that i thought i'd be able to reorder things with. for instance, i'm collecting the ep.s randomly and when i have all in a series i wanted to bring them in and reorder them onto new disks. if i open the dvds on the pc i get a folder with 3x9 files (BUP, IFO, & VOB) but how can i see these things clearly and perhaps retitle etc?
    thx
  2. dmjohnson123
    dmjohnson123
    Nov 25, 2002
    265
    Wetherby near Leeds
    +5
    TMPGEnc's DVD Author 1.6 will do what your looking for - Re-order your Simpons episodes, you can edit out the adverts and create a reasonable DVD menu. I used it to do a Simpsons compilation for my boy and it works a treat !
    Its available as a trial download so you can try it before you buy (around $80 = £40 I think).
    Do a search on these forums to find out more and Razcak has written a great sticky explaining how to convert Ram to -R which includes details on using TMPGEnc's DVD Author.
  3. Halloween Jack
    Halloween Jack
    Sep 27, 2004
    275
    16
    thx, but for the amount of times i'll do it i don't think it's worth paying. i'll keep trying for freeware. but thx anyway.
    cheers
  4. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    DVD Shrink will allow you to compile a new disc with titles taken from other separate discs. It's freeware...
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    ...or you could always just store the episodes on DVD-RAM until you have the ones you want to archive to a specific DVD-R.
  6. Halloween Jack
    Halloween Jack
    Sep 27, 2004
    275
    16
    dvd ram? wouldn't that mean i'd have to bounce off of the panasonics hdd? sounds more work.
    ideally i'd just like to drag in titles to a temp folder, retitle and reorder them then bump them off to a new dvd. nothing too elaberate. that's why i was hoping for something free.
    i have dvd shrink but the titles simply come up as title 1,2 etc. can i retitle these or reorder them? also i'm sure how to take just a few from various dvds to then stick on a new one. is it easy?
  7. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    Yes - but the total work effort is about 30 seconds. It's only a suggestion but that is the benefit of having re-writeable media in a HDD/DVDR.
