How can I reboot PS2 using control pad?
Discussion in 'Playstation Forums' started by incywincy, Sep 28, 2004.
  1. incywincy
    incywincy
    Jan 25, 2004
    67
    Manchester
    Does anyone know if its possible to reboot the PS2 from the control pad like you can with the Gamecube?
  2. Pooon
    Pooon
    Dec 26, 2002
    7,366
    Canterbury, Kent
    +956
    Don't think so.
  3. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    you can with the remote control though :)
  4. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    You can? :confused: Pray do tell :D
    S.
  5. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    i press reset on my remote,et voila it resets,tho i think only on the later models with the infra red reciever,
    voila thats french innit! :D
  6. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Ahh you have the updated Sony remote with the green power/reset button? 'Fraid I've only got the original Sony remote and a first issue PS2 so no remote resets for me :(
    S.
