How can i play Counter-Strike without Quickstarting?
Discussion in 'General Video Gaming Chat' started by gameanoid, Mar 6, 2003.
  1. gameanoid
    gameanoid
    Hi guys,
    How can i plan CS withought having to Quickstart to get onto a game every time???? It is starting to get really annoying having to quickstart and then quit because the games are not connecting to u!!
    Gameanoid
  2. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    I use Wire Play. Down load the browser and once installed you can view all servers there and then. Wire Play is being taken over at the mo by First Net so the service is down tonight. But this is by far and away the easiest way to play CS.
  3. Sinzer
    Sinzer
    May 25, 2002
    5,823
    +1,117
    The best way I have found is using Gamespy 3D (note : not Gamespy Arcade!).
    Just download it and install, then it will update, you can add your servers to a faves list. This also allows to auto redial so if your fave server is full you can allow it to constantly ping until a slot opens up. Simply do some browsing while you wait.
  4. gameanoid
    gameanoid
    Thanx ppl i have downloaded the gamespy 3D as the Gamewire had only 2 servers online!!!
    Thanx
    Gameanoid
  5. Pooon
    Pooon
    Dec 26, 2002
    7,366
    Canterbury, Kent
    +957
    You could also try All Seeing Eye, similar sort of thing to Gamespy only different!.
    Also check out www.bygames.com for a list of FREE, and semi-fast, UK servers.
  6. MonkeyDonkey
    MonkeyDonkey
    May 9, 2002
    401
    UK
    What's wrong with the in game browser :confused:
