how can i play a movie across two dvi screens
Discussion in 'Desktop & Laptop Computers Forum' started by Lenzz, May 26, 2005.
  1. Lenzz
    Lenzz
    Mar 17, 2004
    39
    i have just installed a 6600gt using horazontal span to expand the desktop across 2 monitors. But when i maximize a movie in media player it will only play half of the image on one screen. is there a way to get it to play on both monitors.
    Lenzz
  2. markxtc123
    markxtc123
    Jan 27, 2005
    265
    +16
    Maximizing an application window locks it to one display. If you leave media player in a floating window and then drag the window across both display the movie should appear spanned across the two monitors.
  3. Lenzz
    Lenzz
    Mar 17, 2004
    39
    no that dosent work either its still only shows in the monitor that the majority of the video is in. I have tried this on a radeon 9800 pro and a nvidia 6600gt and the problem is identical
  4. Stellavision
    Stellavision
    Apr 7, 2003
    2,190
    Southsea, UK
    +76
  5. SeanT
    SeanT
    Jan 28, 2005
    6,125
    Coventry
    +371
    Clone the displays in the driver before you watch it, could probably use a taskbar type app to switch between the two modes. (eg. ATI Hydravision)
