I have a M&K KX10
http://www.mksound.com/pdf/spec_sheets/spec_subs/MK_KX-10_sub_specsheet.pdf
As part of a necessary move over to compact home cinema last month it came as part of a package with my M&K K17 and K4's
After selling my enormous B&W ASW1000 this sub is a breath of fresh air. To me it is fast, tight, punchy and rhythmic and just enjoyable to listen to everyday. Despite the xover at 120hz there is no localization. My old sub was set at 80hz and gave it's position away and never kept up with the rest of the audio. It just rumbled whereas the M&K sings a tune.
The only thing is despite a nice smooth low end and no distortion the ultimate low end extension - slam or sofa shaking or that silent room loading in your ears is lacking. The sub is only 8inch and tiny so I suppose that makes sense.
There is no way I will go backwards with regards to speed and rhythm, what do I need to look at to get the big low end slam?
Also you may have suggestions for subs that are even faster and rythmic? Although I can't imagine the need for more.
My budget would probably be around £400-500 s/h and it must be as small as possible.
