How Can I Improve PD30 RGB?
Discussion in 'Televisions' started by Anastie, Mar 26, 2005.
  1. Anastie
    Anastie
    Jul 15, 2003
    1,848
    63
    UK
    +192
    Hi all. I have lived with the following since I got my 36" PD30 18mths ago, but now want to know if I can do anything about it!
    My Sky+ has to be set to PAL because in RGB (as many have found) the picture quality is very poor. I want to improve this if I can.
    I have considered getting a JS RGB to Component converter box, but I have my Sony DVD player connected via Component so I dont think that would solve my problem. My connections are:
    DVD > component
    Sky+ > Scart (set to PAL due to above problem)
    Sky+ sound > optical to receiver
    Does anyone have any thoughts on this. I'm prob missing the obvious. But as ever all advice appreciated.
  2. Anastie
    Anastie
    Jul 15, 2003
    1,848
    63
    UK
    +192
    Lots of views but no answer? :(
  3. stevefish69
    stevefish69
    Jun 25, 2004
    4,183
    +439
    I have connected a second input from the Sky+ box to AV2S using a S-VHS to Scart cable. I would't say its a vast improvement but it certainly looks a lot better to my eyes :rolleyes:
    I still have the Sky + connected via AV1 for ease when the kids & missus are watching and normaly only use the other setting for films.
  4. iaTa
    iaTa
    Mar 11, 2005
    237
    +14
    Hi mate,
    I'm lucky enough to have a Denon AVR-3805 which does up conversion from S-Video to Component. I can honestly say that the difference from RGB Scart is incredible. You could get round you dual component problem by using one of these:
    http://www.js-technology.com/produc...id=49&osCsid=3f8478c46aa0a5bb76c86a8fd8e2ebf2
    But it starts getting quite expensive this way. Have you looked at A/V amps that do upconversion as an option?
  5. billystevo
    billystevo
    Mar 13, 2005
    53
    9
    In my opinion trying to improve a picture from Sky by buying top end cables is a waste of money, e-mail them and tell them to increase the bit rate they broadcast in.
