how can i get sound from tv to amp?
Discussion in 'Cables & Switches' started by beem, May 30, 2005.
  1. beem
    beem
    Mar 9, 2005
    113
    lahndan
    Hi, just wondered if anyone could suggest how i can get signal from the digital tuner in my tv (sharp aquos) to my amp (cambridge audio 640A). There is a digital out on the TV but no digital in on the amp. There are scarts on the tv but none on the amp. Can you get a scart to phono connector? Or should i just connect it to the amp via the headphone out socket on the tv? which is surely the last resort.
    Any help, as ever, is much appreciated,
    B.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
  3. Member 34135
    Member 34135
    You could use a scart adapter and stereo audio cable or you could also use a scart to 3x phono cable and not connect the video phono.
    Most TVs also have a stereo output pair, red and white phonos, in which case just use a stereo audio cable from those to an input on the amp.
    Andy.
  4. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
    I have an aquos and it is connected to my dsp via the red and white rca and works fine,even giving me dd 5.1 when watching films with dd on sky
  5. beem
    beem
    Mar 9, 2005
    113
    lahndan
    thanks for the advice. I have a 22 inch tv i think and i don't think this size has the rca outs. I do have rca in though. Did you just connect them to these? I think maybe the one you have is larger and has rca outs on it. Sounds like the scart to phono is the option to go for unless anyone has a better suggestion.
    Thanks again for the advice,
    B
  6. beem
    beem
    Mar 9, 2005
    113
    lahndan
    actually, i have just noticed that both scarts are AV ins. Does this mean that I can't use them to get the audio out? Sorry if that is a stupid question but i've got to ask.
    thanks,
    B.
  7. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
    AV 1 means signal is input/output AV 2 is output only.another option is connecting your video and using this as a sound output and just turn the video on and select the right channel.
  8. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You can't get DD 5.1 with red + white RCA (phono) jacks. You need an optical or co-axial source to get Dolby Digital. You will be getting Dolby Surround or Dolby Pro-Logic from your stereo signal.
  9. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
    :oops: did i write that, thanks for the correction :smashin:
