Quantcast
How can i get my davs 800 to auto switch
M
maximus desimus
Hi all
i have a sony davs 800 and was wondering if i could somehow get it to auto switch to the av channel the davs dosent have a rgb scart socket so im stuffed really
ive just purchased a sony kvfs36 tv and the ample scart sockets are there but i hope i can auto switch the dvd player like all the other equip ,sky+,vcr
im connecting via a svhs to scart cable ixos 1 and in to svhs scart socket
any ideas,equip,advice
thanks for any help
mjn
if you mean widescreen switching then you're out of luck. the widescreen switching is done by sending a signal/voltage via one of the pins in your SCART. If you're connecting via s-video, which imagine you're doing, then the signal is not present.
M
maximus desimus
thanks
i was asking about switching to the av channel when i turn the dvd player on ,sky+ and the vcr both auot switch to there assigned av channels,av1,av2
thanks again
I am maximus
All u can do is assign the av input to a channel number at least this will be better than having to scroll through the avs,I hope this helps
I am maximus
