Hallsy
Established Member
I have a Pronto on it's way to me and am thinking ahead.
I've played with the ProntoEdit Software a little and it doesn't seem too bad.
Thing I was interested in was say for macros using discrete function like ON or OFF rather than ON/OFF.
Looked on remote central for discrete codes and they have Yamaha receiver ones which will suit me, but nothing else.
I am after codes for:
LG TV (can't remember model right now),
Matsui DTR1/Goodmans GDB3 Freeview,
Yamaha RX-V640RDS recevier,
Playstation 2,
Bush DVD player (not too worried here as I will be upgrading soon).
Will I be able to get discrete codes from learning and then looking at the IR code that the pronto has stored?
Weren't sure how this would work with buttons that toggle functions, i.e. on/off.
Any help or advice would be much appreciated
Playstation 2,
