Hello all
I've recently bought an Optoma HD143X and I'm impressed with the picture which more than lives up to expectations.
However the sound from the built in speaker is no more than adequate at best...
I've tried hooking up my old BlueRay Cinema system (5 speaker + woofer) to it from the 3.5mm audio out on the projector but the sound only comes out of two of the speakers (Front R + L). Is there any way to get the full surround experience with this type of setup / connectivity? I've used a 3.5mm to twin RCA male cable. 3.5mm seems to be the only audio out from the projector. Perhaps from this to a different input on the BlueRay system? However, all I can see on the back of it is:
Can the HDMI ARC port be successfully used? If so what do I need for this?
thanks all
- Digital In Optical
- Video Out
- HDMI Out ARC
- LAN (100)
- Audio In (the ones I have used already)
- FM antenna
thanks all
