How can I get a common remote?
Discussion in 'Home Cinema Control & Remote Controls' started by Eaglesh, Jan 8, 2005.
  1. Eaglesh
    Eaglesh
    Hello,
    I have a Panasonic TV. The remote of this tv was crashed by my son. Can I buy a general remote that can be adjusted to work with this tv? Where do I get it?
    Thank you,
    Eaglesh
  2. jaguar
    jaguar
    Nov 17, 2004
    186
    There are lots.
    The best place to start looking is on http://www.remotecentral.com and use the clicker picker.
    If you don't won't to get into remotes that much visit the Philips site they have universal remotes in each price class.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    a harmony H655 is the best bet for a simple remote to control up 10 devices or get a panny replacement unit
  4. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    A £100 remote (Harmony) seems like overkill to achieve what Eaglesh is asking - especially if his son gets hold of it - ;) . Better to go for a cheap Philips or OneForAll.
