How can I determine door mech on DVD32R?
Discussion in 'Blu-ray & DVD Players & Recorders' started by memmerson, Oct 30, 2005.
Tags:
  1. memmerson
    memmerson
    Dec 12, 2002
    505
    Devon
    +16
    I have (reluctantly) advertised my DVD32R in the for sale forums and I have been asked if I know which door mech I have. Do any of you guys know how I can determine this?
    It has the latest drive mech (S58) and the serial number is: DVD 20105211.
    Any feedback would be much appreciated.
    Marc
  2. Teejoo
    Teejoo
    Apr 24, 2004
    221
    The Netherlands
    +3
    Well,
    besides asking the helpdesk you can see how it performs:
    The latest doormech really closes fast in doorprofile 1. You hear it hit the end quite loud, and you really get the feeling not to stick your finger between it :). Switching to profile 2, it also closes very well, but much more controlled and smooth. Especiallly after it adapted after a few open/closings.
    If you use doorprofile 2 with the older mech, the door probably doesn't close completely.
  3. Miron
    Miron
    Sep 26, 2002
    1,439
    Vienna, Austria
    +56
    Door modification was done on all our players when sent to Huntigdon. But two different door mechs, no, I do not think so. I think the question was rather if dooor mod was done or not.
    Furthermore, on my player, door behaviour actually got worse after door modification.
  4. Joelc
    Joelc
    May 16, 2004
    414
    +5
    This may be a naive questionbut...how does one change the doorprofile that is in use as I have never seen this option in the menu options...
    Joel
  5. memmerson
    memmerson
    Dec 12, 2002
    505
    Devon
    +16
    thanks for the replies guys. So if there is a newer door mech then I must have it because mine does indeed close very quickly hitting the end with a loud thud!
    I would also be interested to know how to change the profile?
    Marc
  6. awaters
    awaters
    May 19, 2004
    25
    The door profile is changed by:
    turn off the DVD32R,
    hold down the buttons display and open/close while turning it back on,
    it will then come up with a prompt, skip- will select A, skip+ will select B.
    (The current profile will be shown in the top left hand corner.)
    We need to get all these special combinations put somewhere for easy access. Does anybody have a full list?
    Andrew
  7. Joelc
    Joelc
    May 16, 2004
    414
    +5
    Thank you...
  8. Teejoo
    Teejoo
    Apr 24, 2004
    221
    The Netherlands
    +3
    I meant 'door modification, not doormech'. But I think the idea how to find out was clear.
