How Can I Demo HD
Discussion in 'General TV Discussions Forum' started by nheather, Mar 16, 2006.
  1. nheather
    nheather
    Oct 6, 2004
    19,767
    167
    Horsham, West Sussex
    +10,048
    I have an HD-Ready Panel (Panasonic PHD8), an HDMI terminal card and reasonable spec PC with a graphic card with DVI out.
    I assume that the only extra hardware that I will need is a DVI to HDMI convertor - is this correct?
    On the software
    (i) Where can I find good HD demos to download?
    (ii) Will I need any special software to run the demos?
    Thanks,
    Nigel
  2. Kalos Geros
    Kalos Geros
    Sep 4, 2005
    2,101
    Croatia
    +136
    check out microsoft (WMVHD), divx (DivxHD) and Apple (QuicktimeHD) sites...respective codecs can be downloaded from the above sites if you don't have them installed, trying to play a HD clip will probably initiate automatic codec download if it's not installed...
  3. nheather
    nheather
    Oct 6, 2004
    19,767
    167
    +10,048
    Thanks very much ... just what I was after.
    Cheers,
    Nigel
