How can I Copy From Sky+ to My Computer?
Discussion in 'Sky Digital TV Forum' started by Ginnser, May 5, 2005.
  1. Ginnser
    Ginnser
    May 5, 2005
    70
    11
    Hello
    I have a program on Sky+ that I wish to copy to my laptop pc, fairly new sony. How do I go about it? Program is only 5 mins in total.
    Regards
    Mark
  2. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    This has been covered a few times and there are eseentially two ways:
    1. If you have a seperate DVD recorder, copy the program onto that and then just play the DVD in the laptop.
    2. If the laptop has a TV input connect the RF2 out on the Sky+ box to the TV in on the laptop, play the programme on Sky and use some TV capture software on the laptop to record the programme. You might also be able to use a USB TV card.
    HTH
    John
  3. Ginnser
    Ginnser
    May 5, 2005
    70
    11
    many thanks.
