How can I copy Date/Time to DVD recorder using iLink interface
Discussion in 'Blu-ray & DVD Players & Recorders' started by amindanial, Nov 2, 2005.
  1. amindanial
    amindanial
    Hi I have Sony DCR-HC42E and a DVD recorder Philips DVDR 615. How can I record Time/Date (data code) associated to my records on the DVDs using iLink (Firewire) without resorting to A/V cable. Are Time/Date information sent with video and audio signals? and if so why I did not see it on the screen of my TV when using iLink cable?
    When I transfer a movie to the DVD recorder the time and date that appear next to the movie icon in the menu of the generated DVD is the time of transferring the movie according to the calender of the DVD recorder. But, when I divide the the movie using the division feature in the DVD recorder the second part of the produced parts gets the correct time from the original movie,i.e. the original date and time recorded according to the camera calendar. It is ok for me to get the correct time next to the movie icon in the menu, but how can I get this without using division feature since it requires using a rewritable DVDs?
  2. HMHB
    HMHB
    Nov 11, 2001
    27,582
    Nottinghamshire
    +6,511
    I've deleted the other 2 threads you've posted on this same subject. Can you please just post one thread per topic.
  3. Benfica
    Benfica
    I was under the impression that Philips DVD recorders allowed to "store" Time/date information as a "subtitle" on the DVD when copying from iLink interface.
    Is that only availlable in some Philips models ? Does your model do this or not ?
    HTH
