How can I control my devices with the cupboard closed?
Discussion in 'Home Cinema Control & Remote Controls' started by rajvirdee, Dec 1, 2004.
  1. rajvirdee
    rajvirdee
    I've got a Pio Plasma, a Denon amp, Pio DVD player and sky + that I would like to control the major operations with one remote.
    The question is that I keep them in a cupboard which has a solid MDF door. I would like to be able to control these bit with the door closed (dont ask why!)
    I like the sound of the harmony range - is this possible with this?
    Or do I have to go for something like the pronto?
    How would such a system work.
    Thanks in advance
  2. pemberto
    pemberto
    Oct 14, 2003
    502
    28
    Huntingdon
    +32
    Have a look at a few websites, http://www.remotecentral.com http://www.xantec.com for a few ideas. You could look at a system like the Philips Pronto and then either use the RF extender or use a IR relay system from Xantec.
    The prices can range from a few hundred upto a several thousands for complete home automation systems like Crestron and AMX.
  3. stevebez
    stevebez
    Jul 11, 2004
    493
    +13
    Had a Xantech system but Ir flooding from plasma caused problems - have just gone RF via (Home Theatre Master Mx850 / MRF250) and while it took some effort in settnig up ... works fantastically now.
    Rgds Steve.
  4. rajvirdee
    rajvirdee
    thanks for that stevebez - may I ask where u got it from and how much ?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    QED make a system called roomlink that will do the job and has discrete IR Outputs not just flood emitters
  6. jom
    jom
    Nov 26, 2004
    15
    Some lateral thinking... How about a cabinet with a glass door?
