Ward Cleaver
I have an Onkyo TX-8511.
It's a very good sounding 2 channel stereo (100 watts per channel), except the bass is somewhat weak at lower volume.
I would like to connect two powered subwoofers to remedy that situation, however my stereo does not have a subwoofer outlet connection.
My question...
Can I connect a powered subwoofer to each channel by simply placing each subwoofer next to my speakers and then running a speaker wire from each subwoofer to each speaker connection?
In other words, can I run a speaker wire from my right speaker to one subwoofer and then run another speaker wire from my left speaker to the other subwoofer?
Thanks.
Regards,
-Ward
My question...
Thanks.
Regards,
-Ward
