4K UHD Fan
Hi All,
My Home Cinema PC is as follows:
Hardware:
P4 2.2 Ghz (Not overclocked)
Intel 845 Chipset (Not overclocked)
256 MB DDR (Not overclocked)
GF4 Ti4400 128 MB
74 GB ATA 100 HD
SB Live Value
LG DVD-Rom DRD 8120B
Sony Trinitron 17" Multiscan
Software:
W98SE (all latest updates & drivers)
W2K Pro (All latest updates, drivers & service packs)
Intel Application Accelerator (latest version)
Power DVD4
Win DVD4
The problem I have is that whatever DVD I watch (my entire collection is Region1) I nearly always get a glitch whereby the DVD drive hesitates for a fraction of a second and this causes the picture to skip a frame or stutter for a second whilst it retries that part of the DVD again.
Layer changes also seem to take up to 5 secs.
I only listen to DVD's on my PC via Headphones so have to use the downmix to 2 channel Audio options on the Software player.
I have tried brand new unopened discs, old discs, cleaning discs and nothing makes any difference.
I have tried the evaluation version of DVDIdle which is supposed to cache the entire disc (if you set the cache size to 9GB & I have then the picture breaks up into little blocks).
I am at a loss to find the bottleneck and I have even rebuilt the PC several times.
This problem happens under either W98SE, W98 1st Edition or W2K with or without the Intel Application Accelerator installed.
Does everyone else get glitch free playback on their Home Cinema PC?
How can I issolate the bottleneck as I do not want to spend money on new components unless I am certain what to upgrade.
I suspect either the DVD Drive (new in June 2001) or SBLive Value soundcard (new in 1998) are the culprits but how can I be sure?
All/Any suggestions welcome.
Many Thanks
Hardware:
GF4 Ti4400 128 MB
74 GB ATA 100 HD
SB Live Value
Software:
Power DVD4
Win DVD4
Many Thanks
