Question How can I check a wall is flat enough for UST projector?
Discussion in 'Projectors, Screens & Video Processors' started by Therealego, Jan 17, 2018.
  1. Therealego
    Therealego
    Apr 8, 2016
    2
    warrington
    I have been looking at getting the Optoma GT5000 UST projector for 12 months and now the only thing holding me back (apart from hiding the cost from my wife) is the wall.
    I have a wall big enough to project near enough 100" and all the media inputs coming in at that wall but i don't know how flat the wall is. Everything i have read has led me to believe it has to be bob on flat for a UST projector to work properly without a screen.
    How can i check the wall without taking the plunge on the projector and finding out the hard way? I'm thinking lasers to check but no idea what to search for equipment wise.
    Any advice welcome.
  2. Mallardo
    Mallardo
    Apr 7, 2016
    527
    Manchester
    +477
    Not sure how you can check that the wall is perfectly flat. Is getting a screen an option? If so, you could see what the picture looks like on the wall and if there are problems get a screen.
  3. Therealego
    Therealego
    Apr 8, 2016
    2
    warrington
    Thought had crossed my mind but replacing the TV with a Projector is a tough enough sell to the wife, having a big screen might put the kibosh on it.
  4. cyberheater
    cyberheater
    Apr 3, 2003
    3,234
    Scotland
    +189
    If the wall looks flat and smooth to the eye then it will be fine.
  5. KelvinS1965
    KelvinS1965
    Jan 3, 2006
    17,085
    +8,067
    Since an ultra short throw model is going to project at an angle then maybe you could test by shining a torch from the bottom. Angle it upwards and you'll see any imperfections.
    I had a similar effect when I first built my fixed screen: I had downlighta above it and they showed every little wrinkle. Since I have a standard long throw projector the wrinkles weren't visible when watching films. With a UST I wouldn't have got away with it.
  6. Vila
    Vila
    Aug 5, 2002
    1,561
    2
    116
    +787
    I would consider sanding the wall flat using a large block and very fine grit paper then repainting the wall with a spray gun - should be able to hire from somewhere like HSS
  7. swiftpete
    swiftpete
    Sep 30, 2006
    5,185
    Notts
    +1,294
    Just get an electric screen. Even if a wall looks good it will still show up any minor imperfections every time you have white displaying. A wall can look fine to the eye but projecting onto it highlights any issues. It annoyed me enough that in the end I got a screen.
