How can I attach this to the wall?
Discussion in 'Cables & Switches' started by blue_harvester, Jan 17, 2005.
  1. blue_harvester
    blue_harvester
    Jul 28, 2003
    108
    16
    Belfast, Northern Ireland
    I'm looking to attach the following speaker cable to the wall from the surround speaker to the ground:
    QED Ultra-flat Qontour UF
    I was thinking of using Prit pads or something along the same lines as these cables are so small. Is there any better way to do this?
  2. blue_harvester
    blue_harvester
    Jul 28, 2003
    108
    16
    Anyone guys? Please help.
  3. russ123
    russ123
    Jul 31, 2004
    826
    46
    South Of The River
    +109
    Are you looking for something that can be removed easily at a later date and won't leave much of a mark? If not then No More Nails is great.
  4. simon100
    simon100
    Nov 2, 2004
    318
    +11
    Depending upon how wide it is you could use cable grips from B&Q etc. You will see them obviously, but might not be that intrusive.
