how can i add a third monitor to a dual screen set up?
shahedz
I have shuttle PC, it is the SNG142 , it has dual screen output which i have connected to two monitors, I recently bought a plasma which can accpet hi def via a VGA, can i add another VGA out put which has seperate VGA settings to the current monitors i have added? Cheers
mjn
Should be able to, using the correct software and settings.
mjn
No, it shouldn't.
shahedz
whats the difference between PCI and and PCI-E,also with my dual screen set up. i have the mouse scroll from one screen to the other (thyere side by side) how would the third monitor (plasma) be integrated it cant be a clone of one screen for the resolution reasons so i am a bit confused, cheers
mjn
PCI is the old style of slot, cream in colour and PCI-Express is the newer type of slot, either blue or brown.
You can have either clone mode or desktop extension.
shahedz
i got a cream slot so assume its old fashion PCI, my processer is AMD 2500 and i have 512 Ram, will i be able to add another card and will it run efficently or do you think it will strain the PC , will more Ram rectify this ?
cheers,
Educated Guess
Look at Ultramon. I use it myself, great utility for managing multiple monitors.
http://realtimesoft.com/ultramon/
mjn
cheers,
Yep, thats a PCI slot. I'd get hold of a cheap PCI card off ebay and see if the setup does what you want. I got a new Matrox something or other for £7 off ebay a few months, excellent picture quality.
