How big is too big....
Discussion in 'General TV Discussions Forum' started by spoony77, Jan 11, 2019.
  1. spoony77
    spoony77
    Nov 11, 2005
    64
    Hi people,
    Currently hanging my nose over a 65" 4k TV to replace my 50" plasma but am concerned that this TV could be just too big for our lounge.
    The room is 13 foot by 13 foot and we sit about 9 foot from the TV.
    Can anyone comment on if this will just dominate the room too much?
    Would wall mounting help In this respect?
    Regards
  2. simonlewis
    simonlewis
    Jul 31, 2014
    4,450
    stockport
    +1,644
    I wouldn't worry about it being too big, you should soon get used to the size after a couple of days, and yes wall mounting would help.
  3. Norman
    Norman
    Jul 14, 2000
    1,729
    116
    Herne Bay
    +587
    LG can now offer you another solution - their new OLED roll-down TV :)
  4. Hixs
    Hixs
    Jul 24, 2015
    2,792
    France
    +1,570
    I went from a 720p 32" to a 4k 55" a few years back, that was an eye opener for a while. As above though, you get use to the additional size pretty quickly.
  5. John7
    John7
    Aug 6, 2004
    2,701
    +901
    65 inch is the perfect size for that viewing distance and 4K. Room domination is what’s needed for the cinematic experience!
  6. Over by there
    Over by there
    Mar 21, 2016
    982
    63
    Wales
    +384
    With the space available, I wish we had gone to 65. I don't consider TV's taking over rooms as an issue. Walls are dull to look at.
    We bought a cabinet stand that held the TV at the right height for our sofa viewing. Saved messing around with dry lined wall fixings etc. and contains the players and amp and all associated cabling. No wall runs to worry about.
  7. Trollslayer
    Trollslayer
    Feb 11, 2007
    23,921
    Poole
    +9,291
    A good guideline is the viewing distance is about 1.5 times the screen size, works for me (65" at ten feet).
  8. Mr X
    Mr X
    Aug 8, 2006
    6,804
    3
    +2,394
    I know too many people that spent a small fortune on a new TV and very quickly regretting not getting the next size up!
    Given your room and distance, 65 sounds ideal. As said by someone else, it may seem big for the first week or so but it’s amazing how quickly you adjust.
  9. digger99
    digger99
    Jan 27, 2018
    644
    46
    Pakistan
    +118
    Don't mess about lad, slap a 75 incher in there you won't regret it.
  10. adnydrum
    adnydrum
    Nov 10, 2009
    43
    11
    Enfield
    +4
    Well I'd say yes; sounds overpoweringly humongous, but I know others here will be more supportive
  11. adnydrum
    adnydrum
    Nov 10, 2009
    43
    11
    Enfield
    +4
    or is the room not your only living-room/lounge? If it's a dedicated tv room then in that case do whatever
  12. Leo31291
    Leo31291
    Jul 22, 2010
    970
    London
    +374
    If you need to knock a wall down it's probably too big.
  13. digger99
    digger99
    Jan 27, 2018
    644
    46
    Pakistan
    +118
    if its slapped on the wall surely it would make more space in the room.
  14. Sonic67
    Sonic67
    Sep 14, 2006
    43,198
    11
    167
    Home
    +21,238
    It's your house. What do you want?
  15. wass1985
    wass1985
    Oct 28, 2012
    312
    28
    +43
    That's why I hate chimney breasts, new houses are much better to fit a big TV in unless you are planning on wall hanging your set.
  16. Over by there
    Over by there
    Mar 21, 2016
    982
    63
    Wales
    +384
    Tricky if the house comes with a chimney. However when we bought our house there was a fake fire place! House never had a chimney. That fakery soon went.
    Although newer houses care needed with correct fixings for dry walls I would imagine? The fuss for the wall mounting is why I went cabinet, allows you to move it easily as well.
  17. Stinger69
    Stinger69
    Jun 8, 2006
    723
    46
    Lincolnshire
    +234
    Do you think it's too big? (Who gives a damn what anyone else thinks?)
    As long as you can get it through the door, it's not too big! Mind you, tiled tvs might be the future, so even that limitation will be gone!
    Andy
  18. lgans316
    lgans316
    Aug 24, 2006
    11,835
    RM16
    +2,362
    After owning a 65" OLED for few months, now beginning to feel that it is not that big and craving for a 75" or 77".
  19. Smudger558
    Smudger558
    Aug 12, 2015
    169
    4
    28
    Brighton
    +65
    I had a 65 Panasonic cx802 which was good I changed to a 75 xe94 and to start with it was massive but you soon get used to the probably about a fortnight but imo bigger is best and on telly quality the xe94 is about 3 times better than the xxx
  20. Smudger558
    Smudger558
    Aug 12, 2015
    169
    4
    28
    Brighton
    +65
  21. Smudger558
    Smudger558
    Aug 12, 2015
    169
    4
    28
    Brighton
    +65
    If your going to go big it needs to be good as well or it's a waste of time
  22. AVRAG
    AVRAG
    Nov 8, 2015
    521
    4
    47
    UK
    +122
    In answer to your question... too big is too big when you don't watch content that suits it. No point in watching DVDs on a 75". If you plan on watching 4K though, don't go smaller than 65"
  23. chaparral
    chaparral
    Apr 8, 2006
    1,880
    Planet Earth
    +229
    I have my 65" wall mounted in a 12 x 9 foot room and I view it from about 10 foot away..
    Yes it does dominate the room but the pleasure I get from watching movies on such a large screen I no worry about that..
  24. Smudger558
    Smudger558
    Aug 12, 2015
    169
    4
    28
    Brighton
    +65
    I sit 10 ft away from a 75 and it is spot on
  25. Derek S-H
    Derek S-H
    Jan 2, 2005
    3,237
    164
    Brighton
    +2,046
    Room is 14 x 10 and I sit nine feet away.
    TV is probably too high (the Centre speaker is nearly level with my chest when I'm sitting on the sofa), but 65" seems just right for both TV and films, SD and HD.
  26. Bendora
    Bendora
    Monday
    3
    4
    Glückstadt, Germany
    I liked my 75" Q9FN when watching on it. But during the day it is a big black hole, due to the fact my wife doesn't use ambient mode and turns it off. And therefore I had to send it back to Samsung.
    Try to keep that in mind also. How does it look and fit in the living room during the day or when it is not used. Sizes above 65" tend to distract the rooms balance.
  27. martinthorn1
    martinthorn1
    Mar 6, 2011
    203
    Hampshire, Uk
    +31
    I actually find size compensates for a non perfect picture; have a 55" 2017 Oled and a 100" 720p inexpensive DLP projector setup. For film nights the projector often wins out despite having lower resolution and worse blacks as the sheer size makes it more 'cinematic'/immersive. But this is because the projector is significantly larger..
