Good evening all.
First post but long time lurker.
I would be obliged if someone would point me in the right direction.
TV- Sony KDL32V2000
DVD- Sony DAVS300.
Cable distance 20metres routed under wooden floor clipped to the side of joists.
The tv has plenty of scart sockets and a svideo on the left hand side.
The dvd has a group of phono sockets and a svideo socket.
Am i correct in thinking that the svideo is C&Y, so visual only, so the dvd has its 6 speakers to output sound,.
Is the SY option the best way to go, the cable would be run well away from mains cabling to prevent inductive interference etc.
are 20metre sy cable readily available.
is there a british standard for this type of cable or what would be a reputable manufacturer of this type of cable.
handy with the soldering iron if cable can be purchased seperately.
many thanks in advance for your time
tony
TV- Sony KDL32V2000
DVD- Sony DAVS300.
tony
