How best to clean my av rack
Londondecca
I would start with something like Peek which is a mild chemical cleaner, sold at Halfords and some DIY stores
Digger
Thanks Londondecca. Is white spirit a no-no?!?...just wondering about stuff that is lying about the house. May pop in to Halfords tomorrow. Any other ideas?
Londondecca
I would stay away from white spirits. Peek will cost only a few £'s and is very safe to use. Maybe Durlglit might help as I do not think it is a abrasive cleaner. The trick with cleaning is to use the mild products first unless you know what caused the problem and the type of material your trying to clean
Trending threads
