Quantcast
How best connect the CD-82 ?
Barend
Always used my CD player via phono out to the A85, but now I can also use the coaxial out to feed my Harman Kardon AVR-5550, which replaced the A85 to get rid of two completely different setups- surround and stereo.
Any idea what is the best solution?
What I think it boils down to is which DA converter is best- HK's or Arcam's.
Am I thinking right here?
Barend
MarkE19
Yes, you are thinking right!
It all boils down to your personal preference. In most cases even the best AV receivers DACs are only good, not great for music. Therefore I would think you would be better useing the DACs in the Arcam, after all that is a large percentage of what you paid for when you bought the CD-82. If in any doubt though try both and go with the option that sounds best to you. You are the only person that needs to be convinced of your choice.
Mark.
Barend
Thanks for advice!
I think I'll connect both ways, so I can choose between real uncluttered stereo and coax for surround modes, because I think using some stereo-to-surround mode the HK would have to A-D the sound again, right?
Incidentally- yesterday evening I compared the HK vs the A85 for sound, must admit the Arcam amp WAS better controlled, but the HK was quite good, so I'll bide my time until surround kit is out with real good sound (AVR300 ?).
Barend
