alienmuppet
Established Member
- Joined
- Apr 10, 2013
- Messages
- 65
- Reaction score
- 8
- Points
- 19
Please see re-post a little further down the thread.
I think you'd get good results from EQ to trim down the modal ringing as the underlying decay times look pretty good already. If the room is completely dedicated and you intend to go full on into room treatment then that's a different approach that can work.Anyone? Is that waterfall something that can be improved with something like Antimode / BDP or would a few bass traps be better? Or both? Thanks..
Thanks Steve.
