btsam
i hope this post doesn't offend the goys on here using 'proper' scalers
i'm just listening to the current podcast regarding scalers (which is well worth a listen!!) and thought i would ask this possibly dumb/boring question?
with regards to the scalers built in to 'off the shelf products i.e. upscaling dvd's / plasma and lcd tv's and also the much talked about sky hd box;
how bad are they and more importantly, which ones are better than others
i.e.
my samsung plasma uses a genesis/faroujda for scaling/de-interlacing
i also own a samsung dvd-hd850 which uses a zoran-vaddis for video processing
and the new addition - sky hd which i believe uses a broadcom chip for video
bit of a 'mixed bag'??
in your valued opinion which one of the above chips does the better job at scaling/de-interlacing
at the moment i'm struggling a little to find the best overall 'compromise' between relying on the display to process and the external equipment to do the job
don't get me wrong if i had the funds i'd have bought a lumagen already but i've not won the lottery yet!
so far i've noticed that the scaler in the tv does a better job running via rgb scart for sd material than the sky hd box running 576p via hdmi!
also running the dvd player at 720p seems to get the best out of the player via hdmi vs 576i via component
i'm a little new to the whole film/video detection etc thing but i get the impression that good de-interlacing and scaling is a good place to start at
regards
sam
i.e.
regards
sam
