How are you splitting sound??
Discussion in 'Plasma TVs Forum' started by Supersonic72, Mar 16, 2005.
  1. Supersonic72
    Supersonic72
    Jan 10, 2005
    246
    Just wondered how you all rig-up sound with your plasmas?
    I've three or four AV sources (DVD, NTL box, VCR and PS1) and
    have a multitute of scart cables everywhere.
    Is the best way to have them all routed through a SCART switcher
    like the Quintro or Joytech and take the audio from that into an amp??
  2. Piers
    Piers
    Dec 11, 2002
    1,995
    Cheshire
    +230
    The usual way of doing it is to use the A/V receiver as the audio switching "hub".
  3. Supersonic72
    Supersonic72
    Jan 10, 2005
    246
    But what if the device, like ny VCR that only has a SCART output.
    How do you 'rip' the sound out of that to an amp??
  4. dvdsubtitles
    dvdsubtitles
    I had a simliar problem on my old system, my Pace digital box was one of the first released, and all it had was a scart cable coming out.
    I used an adapter from Maplins to separate the audio from the scart cable. This adapter plugs into the TV scart socket, and the freeview scart cable plugs into the adapter. On top of the adapter, there are composite, audio L and audio R sockets. You can use these sockets to feed the audio from the scart cable into an amp.
    Not a very neat solution, but it solved the problem.
    Mat
  5. Supersonic72
    Supersonic72
    Jan 10, 2005
    246
  6. Supersonic72
    Supersonic72
    Jan 10, 2005
    246
  7. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    that would do the trick
  8. dvdsubtitles
    dvdsubtitles
    Neither of those links is the adapter that I have, but they both look better. Mine was just a solid block with 3 din sockets. I bought mine about 4 years ago, I am sure these are far better products that have been released since.
    As mep says these should do the trick.
    Mat
  9. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    If you have Sky or NTL, then you can use the audio output from the box. Anything plugged into it (your VCR) will route it's audio through these sockets.
    If not, does your TV have audio out?
  10. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    Must read first! You have NTL.
    I had a setup very similar at one point. Here's what I did:
    Playstation into 2nd Scart on VCR
    VRC into 2nd Scart on NTL
    Audio out from NTL will now service these 3 devices.
