how are sat/tv wall outlets installed?
Discussion in 'Cables & Switches' started by kbgnat, Jun 18, 2005.
  1. kbgnat
    kbgnat
    Dec 18, 2003
    30
    hi,
    ok, i give up! Could someone be so kind as to telling me how to install a sat/TV wall outlet I bought out of maplins. I have managed to figure out how to wire up the satellite connector, but I have no idea how to wire up the tv coax cable.
    The actual internals looks a little like the ones shown at this link.
    http://www.victoryelectronic.com/satellitewalloutletplate01.htm
    Thanks in advance.
    Anymore head scratching then I am scared I will have no hair left.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,389
    Somewhere in South Yorkshire
    +5,777
    Not really a customer installations question - more cabling I'd say. So, moving...
  3. vex
    vex
    Mar 8, 2005
    2,905
    103
    London, Home Counties & North West
    +261
    Was the face plate you bought called a 'Triplexer'?
    If so this is not designed to take two input cables. Just the one satellite feed.
    Satellite frequencies can be combined with TV, FM and even DAB signals as they all sit in different frequence ranges.
    Usually there will be a 'combiner' device in the loft / near the aerial that brings all the signals together and then feeds them down the one cable.
    If you have two cables from the loft / aerials then you need a different and more specialised outlet. They do exist you just need to be specific about what you ask for.
    Chris
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Vex is correct, you need either an outlet that allowds for independent feeds (SAT and TV/FM) or you need a multi-switch ('combiner') in the loft that sends all the signals down on one single cable.
    See also this thread here: http://www.avforums.com/forums/showthread.php?t=220407
