How 720P vs 480P affects DVD quality on LCD.
Discussion in 'Blu-ray & DVD Players & Recorders' started by benmiles, Mar 22, 2005.
  1. benmiles
    benmiles
    Feb 9, 2005
    47
    Hey guys. I currently have a Denon 2800 (working perfectly - for once) DVD player. On my CRT the quality was stunning. On my new LCD I have it connected via component (quality cables) and progressive scan is on. There is a lot of noticable artifacting and some soft edges that give a similar appearance to dot crawl. Does anyone know how an upscaled DVD to 720P would look for comparison, from say one of the new Denons with HDMI on this screen? I understand that it would be closer to native resolution, but as I understand it the artifacts and soft edges would still be there. Am I right, or should I spend a small fortune on a new player :).
    PS - it isnt the quality of the 2800 that is the problem. I used a pioneer at 480P and the quality was even worse!
  2. BUFFY FAN
    BUFFY FAN
    Jan 6, 2005
    142
    Huddersfield
    Hi benmiles I have the denon 3910 hooked up to the panasonic AE700 projector which is LCD, via HDMI 10m cable and I think the picture looks better when the dvd player is upscaling to 720p rather than the normal 480p. Infact it looks amazing. Just looks that bit sharper.
  3. benmiles
    benmiles
    Feb 9, 2005
    47
    Thanks for the reply!
