Ugg10
Hi all, long time no posting, apologies for the absence (but have been active e on the Hifi section).
Anyway, planning this years holiday (first for three years) and will have an opportunity to do a fair bit of snorkelling. Therefore I would like to get some half decent underwater photos (less than 5m probably) so was thinking of getting one of the plastic bags. I have an old Canon 550d and ideally would like to use my Samyang 14mm F2.8 as I can just set the aperture and focus to around 2m and it will be a point and shoot. If the bag proves reliable then I may chance my 6D in it.
However, most of the cheaper bags (approx £50) seem to be limited to 80mm lens diameter but the Samyang is 85mm.
So, does anyone know of an underwater housing/bag for an SLR with a wide lens that would fit, ideally less than £100, or suggest other options? I will also have a look for smaller cheap EF lenses that may also do.
Thanks in advance.
Thanks in advance.
