Yes that’s the normal configuration for a zoned heating system. The thermostat controlled radiator would cycle the CH service on and off, typically set at a higher temperature than the rest of radiators on tvr’s. Those tvr’s set typically at a slightly lower temp, would then turn those individual radiators on & off. The other issue with having a tvr on a stat controlled rad, is it could close, when the CH pump is still being told to circulate water.
When I’ve had to access behind plasterboard for cabling, I’ve carefully cut a 100mm hole, make sure there’s no services, cables pipes etc. The hole can easily made good, by fixing a 2 x 1 150mm baton in the centre of the cut hole, then fixing the cut circle back into the hole.
