All soffit underside panels fabric wrapped and fitted. Also wrapped the projector box to match. Vent for projector intake fitted, provides passive intake from kitchen. Will tidy cables and fit the shelf tomorrow.
Foam added to atmos speaker back boxes, as apparently the MK IW85 came with foam originally - bought these second hand.
Soffit sides all primed. Will be cut to the correct lengths and then fabric wrapped before fitting over a lengths of OSB.
Extract vents above the cab, still need to connect up this extract hose.
Downlighters fitted and wired. (Still have two to do but ran out of time and patience today.
Pleased with how it is coming on.
What the down lights do show though, is how crap the Dulux paint is. It marks so easily. It shows up dust (of which I’m still creating some) and if you wipe it, it looks horrendous. Will clean it up and give another coat. The plan was always to have MVel curtains in front (Thank God) but it will definitely need covering with curtains or panels with a 4 and 8 year old. Utter garbage.
