EDAV
I have posted this thread here because i cannot find anywhere else.
Anyway i have a Optima plus 2 House alarm which goes off at the sounder in the outside box when the Electric power is turned off.Nothing happens on the control panel inside (No display and quite)
I have installed a new 12v battery inside the panel and it does not seem to have made any difference. When the power is re-instated it goes off again but i am able to disable the sounder as the panel is now lit.
Please help as i do not want to have a new alarm system. I am capable of repairs but need a little help or advice from a specialist.
Thanks you
Thanks you
